tstat
Paul Fredricks_3
Paul Fredricks_3 Member Posts: 1,556
THanks, I'll check it out. Anyone know the model number?
  • Paul Fredricks_3
    tstat
    I've listed this thread in the control section of the wall, but decided to put it in the main part too in case someone has an idea. I'm looking for a limited range tstat for a multi family application. Every simple single stage stat that I find has a max of 90 degrees, like someone needs to have their house that hot. The old T822D1719 had a max of 72, but since the end of mercury that is no longer available.
    I don't want to use a digital stat with lockout since I can see a frustrated tenant putting a knife through it. I looked at Honeywell and white rogers, no luck. Western Control has one I'm looking at now, though I have no experience with them and not even sure where to get it.
    Any ideas?
  • adambuild
    adambuild Member Posts: 422
    Use a Honeywell VISIONPro 8000 with a remote sensor in the apartment. If "knifed," they're only about $30.
  • Paul Fredricks_3
    I left out one thing. The tstat wires don't go to the basement which is where I'd have to put the stats. They just go to a Taco ZV in the apartment. To go the remote route I'd have to pull new wires which adds to the expense which the landlord would rather not pay (shocker). This leaves me with the options of a cheap low range or an expensive 8000. Rather find the cheap one.
  • lee_7
    lee_7 Member Posts: 457
    why not try the wireless thermostats. I believe honeywell makes system that might work for you. I know the company i work for has 1 in service for normal stats and works great.
  • Ken D.
    Ken D. Member Posts: 836
    Stat
    Carrier makes a radio controlled remote stat. They work well.
  • Glenn Harrison_2
    Glenn Harrison_2 Member Posts: 845
    Just had a thought
    If you get the Honeywell Focus Pro 5000 T-stats they can be programmed in the installers menu so that the setting cannot be set above a predetermined temperature, such as 68*. The FocusPro can also be configured for heating only so you don't have the "cool" and "fan" functions showing.
    If you choose these stats double check them out of the box as the temp limit feature did not come with the first generation of FocusPro's.
  • jalcoplumb_7
    jalcoplumb_7 Member Posts: 62
    Second that.
    I use the VisionPro 8000 as well. You can lock out the screen and set temp. limits hi and low.
    Love them.
  • Home Depot Employee
    Home Depot Employee Member Posts: 329
    people are savy today
    Just remember
    Unless you use a remote stat or one that requires a code, anyone can go online and get the intructions to reprogram it.
  • john Cockerill_2
    john Cockerill_2 Member Posts: 33
    remote
    White Rogers 95 series Danfoss 7000 remote
    www.Exqheat.com
  • RJ_4
    RJ_4 Member Posts: 484
    wireless
    Be careful, wireless systems have problems in buildings that have alot of concrete with rebarb. Also buildings that have cell phone comm. equip. on roof.
