Combustion anlyzer
Eric K
Member Posts: 3
Anyone use a uei C125 analyzer? Good or Bad?
I use a
UEI C127 which is very similar. The C127 does NOx which the 125 does not. The make a really good product I have been pleased with it so far...0 -
UEI
I have one and like it a lot, except that I don't use it a lot and the instructions are better, but still not written by a burner tech, or at least someone who uses the machine a lot. I am sure using it more will make it easier, but I do like the unit.0 -
Tester
I have used the UEI for years. When I managed a company that is the tester I bought for the company's techs. A little more durable that the competitor's testers. But, the repair turn around time is horrible and the costs are much greater that any competitor's. I still have mine and have not used it for 3 years because it needs to be repaired again and last time it cost almost $700. I have been using the old Bacarach until I can afford a new Testo.0
- 167 Indoor-Air Quality
