taco mastermind II
darren_4
Member Posts: 4
help if possible
i have a customer with a taco mastermind II energy saver control.the problem is when control is in normal mode boiler runs fine,when control is in save mode burner doesn't fire.system is forced hot water 3 zones /taco zone valves with domestic. when in save mode all z.v. are opening fine ,circ comes on and runs burner cold.
thank you
thank you
attached is the instruction sheet for the obsolete mastermind. Hopefully this helps you.Joe Mattiello
Taco Comfort Solutions0
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
