radiator valve seized
GusHerb
GusHerb Member Posts: 91
the best thing is graphite packing it comes in a string and you string it around the valve stem and screw the nut back on and all should be good.you can get it from any plumbing supply house.
j.h.
  • nack
    nack Member Posts: 1
    Hi,
    Just bought an old house with about a dozen cast iron rads for heating. Each rad has a large main valve, used for crude heat control per room. Problem is that none of these valves actually turn. Worse, one of these valves is leaking from it's stem. I drained the system and removed the cap from the leaking valve, but I am unable to find anybody who provides washers or parts. Please suggest an alternative gasket material or supplier that I can use for this leak. If it works then I'll take the others apart and try to get them unseized too.
    Also I am drywalling behind these rads and the rads need painting too. I am tempted to remove the rads during this rennovation period and refinish them on the workbench. How risky is removal of these rads? I am worried about creating leaks when I reinstall them. But removing them would make for better walls and better refinish on the rads.
    Decisions, decisions. Any advice would be appreciated.
    Thanks
