boiler and hot water question
post this as a new thread... It may get lost here! You may not realize it, but you are tagging on to another person's question and will not likely get individual attention.
Cut or Copy and Paste your message. Then click on "New Topic". Make sure the appropriate category is checked, Heating questions is usually the default but there are controls, refrigeration and energy efficiency categories also. Choose the appropriate one.
Paste your message into the message field. Type in a subject line, your information then "Post" and you are on your way to a wide audience eager to help.
Brad
  • chuck_6
    chuck_6 Member Posts: 107
    We have a 1989, 50,000BTU boiler and a 41-gallon Amtrol hot water making that we are looking to replace. The boiler heats a 300 sq ft, poorly insulated sunroom and the hot water maker. I know I have to tighten up the sunroom (insulation and better windows). The way I see it I have a few options - get a bigger boiler (approx 100,000BTUs) that would supply enough hot water (currently, cannot take back-to-back showers), get another smaller boiler and install a mixing valve, or we have a radiator in our kitchen that was capped off many years ago - we can drill through the wall, extend the piping out and have a radiator sit about halfway up the wall (eliminates the need for a second boiler and get a stand-alone hot water maker). Please advise with any thoughts or new ideas.
    Thanks,
    Chuck
  • Ken_40
    Ken_40 Member Posts: 1,310
    I know it's a pain...
    But the boiler has plenty of power, the Amtrol plenty of starage; but, something's wrong.
    That combination should allow 3+ back-to-back showers and then some!
    The problem is probably the coil within the Amtrol being coated with scale/lime/calcium carbonate - and the heat NOT getting into the water as it should.
    Amtrols are notorious for this over-time "flaw." You could spend a day pulling the coil out, wire-brushing the crud off the coil and perhaps using vinegar or some mild acid to thoroughly clean it off. Or, you could go the direction you intended, and save time, but at a much larger expense. The stainless steel indirects out there (Triangle and the Weil McLain variant) are good choices with lifetime warranties.
    To verify the problem, I'd pull the coil out and re-gasket the port, and make sure before spening any big money. If the boiler is only putting out 130F water, or some similar "problem," you want to find the actual culprit before taking the big hit on a total replacement.
    You may be at a juncture where re-thinking the entire heating system and domestic hot water interface may up the efficiency of the entire heating and hot water systems as a single upgrade for both bathing and whole house comfort.
    Thinking of a single water heater (with today's fuel costs) makes little sense as the ultimate solution. Cheap up front? Yes. Long haul? Nyet!
  • chuck_6
    Thanks Ken
    Ken, I appreciate your comments. In the past I've asked our heating people about it and they have said the Amtrol is self-cleaning. Even though a pain, I guess it would be a lot less costly to clean out the coil.
    Since both the small boiler and Amtrol are old, and in re-thinking for the future, others have mentioned high efficiency boilers that vent out the side of the house, but I just don't see the need to heat one room and for our indirect.
  • Joe Brix
    Joe Brix Member Posts: 626
    Maybe a priority control
    for the indirect would be a better solution. 100K for a 300sq ft room sounds like overkill to me unless the sunroom is open to the elements. I would work on insulating the sunroom unless you like throwing money out the window (literally). Let the sunroom go with out heat for 1/2 hr while it gives all 50K Btu to the indirect. Aftr 15yrs, the tank's coil is at least owed a cleaning.
  • chuck_6
    Thanks Joe. I forgot to mention we do have a priority system. The sunroom is poorly insulated with big windows. I know I need to tighten it up, and get a good cleaning on the hot water maker. Since both are old, if we do have to get a new boiler and indirect, it sounds like we should get another 50-60,000BTU, which would probably be more efficient than our 50,000BTU output (36,500BTU input) Utica.
  • Byron
    Byron Member Posts: 6
    Radiator-hot water heating system
    I just moved into an older house. The heat has not been turned on for at least one year, maybe two. I feel like I've done everything correctly to get the system running. The problem is I can't get the pump(motor) to circulate the hot water. When the switch for the pump is on the burners shut off. If I shut the switch to the motor off the burners will stay on and heat the water. I feel like the pump is OK because it worked last weak. What could I be doing wrong? I have no experience with this. Maybe you can give some ideas of how this system should work.
  • Couderay
    Couderay Member Posts: 314
    re post
    Byron put your question in a new post
  • Byron
    Boiler problems
    I just bought a 1930's home which has the original boiler/ hot water/radiator heating system. It is a one pipe system which has not been in use for two years. The problem I'm having is getting the pump(moter) to circulate the hot water. When the switch for the pump is on the burners shut off. If the switch is off the burners stay on and heat the water. I think the pump is OK - it worked last week. What could be going on? -I really have no experience with this type of heat at all - but am learning quickly - Help
  • Byron
    HOw?
  • Brad White_9
    Brad White_9 Member Posts: 2,440
    You should really
    Brad
  • Byron
    How?
  • Jeff Lawrence_25
    Jeff Lawrence_25 Member Posts: 746
    On the main page of the Wall
    There is a phrase at the top that says something like "New Thread."
  • Byron
    thank you VERY much
  • Brad White_9
  • Jay_30
    Jay_30 Member Posts: 1
    tankless water heaters
    I have a 4year old boiler with a tankless water heater, the problem is i don't get any hot water. A plumber told me i should not have a tankless because i have hard water, should i go with a reagular water heater instead.
    Thanks Jay
