Radiant Heat Loss Program
adambuild
Member Posts: 422
Does heat loss software for radiant differ in that you need less btu/hr because of the mass that is transmitting the heat to the space/people?
Does anyone know of a radiant heat loss / design program that has warmboard as one of the methods?
Ray0 -
substitue
I use thin slab concrete setting for Viega's program when figuring warmboard - so far its worked ok.
heatlink
i use healink design suite which has their dry above system, very similar to warmboard.0 -
radiant program
Watts Radiant has on.0 -
Mass is just a flywheel.
it smooths things out at the price or responsiveness.0 -
You've actually got a safety factor built in doing that, if you're doing reset water temps/consistent circulation. Not a huge one, but this is a decent band-aid method until software catches up.0
- 167 Indoor-Air Quality
