Help no heat sort of?
Chris Williams_7
Member Posts: 1
Help pleas, suddenly I have come home tonight and the heat is working sort of, the circulator pump doesnt seem to be running at all, but if I turn the therm up in the 3 zones I have some heat does come through, but the circ never seems to run at all. I opened the transformed and checked c1/2 going to the circ and I dont see any power going there. I am at a loss as to what is wrong because I do have some heat but clearly not much water is going through the pipes, it alsmost seems like its just like a slow flow. The water zone that runs my tankless hot watre is working fine and that circ pump is good, any ideas, I have a call in but just want to make sure I havent missed something. Thank you so much and Thanksgiving wishes to you.
Chris
Chris
Sounds like the hot water is somewhat migrating through your system, but the circ is dead. Check power @ the circ. If no power, check controller./ What type of controller does the circ attach to? Pictures of the boiler / circ? I just did a job where a Thremostatic union ws blocked. Could be anything. Make / model of boiler?
TimJust a guy running some pipes.0 -
Its a 10 years old peerless wbv series. The circ does seem like its dead, but im not sure if its the control tht is dead, it definitely powers the h20 zone fine, but I tried to shove a meter into the circ ends, and it doesnt seem to have any power, so I am wondering if its the controller, so maybe its bad. Any ideas would be great
Yes
calll someone who doesn't have to guess and will have the parts necessary to repair or even better upgrade,a multi-speed circ or Digital aquastat for example.
But what is the controlling devise? Honeywell? Taco? Model #? Zone valve? Pictures?
- 167 Indoor-Air Quality
