Low temperature fin tube
Charlie from wmass
Member Posts: 4,414
If by work you mean transfer heat to the room then yes. Lots of reset systems on baseboard in mass. just need to match the heat curve to the heat load is all.
cell # 413-841-6726
cell # 413-841-6726
Questions about the low temperature ratings of fin tube bb. What are your thoughts on the bb when the temperature is really low during reset? I am figuring 260 btu/ft @ 130 supply water temperature. This temperature will meet the heat loss requirements at design. My question is how well will the bb work during really low supply water temperatures in reset? Has anyone installed such a system? My concern is that when the bb is receiving low water temperatures below the 130 design will the bb work?
Thanks,
Marc0 -
Clarification
My concern is when the delivery temperature is low (100 degrees) or less, will this still heat the space? I know it will work at 130 degrees. I would think that the but/ft will drop off alot and then the fin-tube would lose it's ability to distribute the heat.
Thanks,
Marc0 -
I do it all the time
I program the base temp of bbd curves at 100. If the water temp is high enough to make the bbd warmer than the surrounding air, then heat transfer will take place.
I've got one house where the garage slab, basement slab, 1st floor plated tube, and the 2nd floor fintube bbd all run at 120F.0 -
Check this out
Your Tax Dollars at Work from BNL/DoE:
Dr. Thomas A. Butcher and his team.0 -
Yep
Yep
Key is "over size" the BB >> I run 130-140° at DDT-9° and 90 - 120° in the 25-40° >> heats the home effortlessly0 -
Mark,...
In the past we have used: http://www.hawkstoneindustries.com/html/htgedge.html
and other baseboard at temps as low as 90' as an add on in radiant systems as well as multiple times in childrens nurseries and school common areas because of the concern of scalding at higher temps. At higher supply temps the heating edge output is phenomenal! You can considerably downsize as another advantage as a design consideration.
In one installation we have about 16 feet of heating edge in a 15 x 18 room, three outside walls running at about 100' supply temp, it heats the room in about 15 min, on 0 degree days and is the most comfortable room in this installation full of rooms with other cheaper baseboard. It far outperforms conventional perimeter heating and is very durable much more so than any conventional baseboard.
Unfortunately many supply houses dont stock it, but many can order it quickly enough.0 -
Make certain that the boiler "brain" or the control system has a "minimum temperature" function. Most, but not all do.
Optimize the reset curve for "normal" weather and "typical" operation by the user. If you then find a problem not enough heat in quite moderate weather you'll then use the "minimum temperature" function to say, "Hey--my emitters need at least this temperature to be effective." Without the "minimum temperature" function you [could] be forced to use a reset curve that's far from ideal.0 -
Good Stuff
Another one added to my collection0
- 109 Chimneys & Flues
- 976 Plumbing
- 387 Solar
- 17 Recall Announcements
