control wiring Scheme
Empire_2
Member Posts: 2,340
If I'm not mistaken, Arzel sell's the ad on slave boards. I'm not sure if they can be installed on all zones, but check with your Arzel rep.
Mike T.
Mike T.
Multi Zone control wiring radiant heat with heatpump
I am in the midst of a new project which consists of a 6 zone radiant heat system with 6 matching heatpump zones. The boiler is going to be controlled by a taco zone panel and the heat pump is going to be controlled by an ARZEL 6 zone AIRBOSS panel. I would like to control both systems and each zone from common stats. The boiler is a Munchkin and the heatpump is a Heil 5Ton W variable speed AHU.I was thinking of having an od stat tied into the ARZEL to control fossil fuel and bring the radiant on.Any suggestions or recommendations?0
- 15.8K Strictly Steam
