raw oil smell with new boiler
Steve Ebels_3
Member Posts: 1,291
> My contractor just replaced my ancient steam <BR>
> boiler (converted from coal) with a new Smith <BR>
> boiler Model 8 series and a Beckett burner. <BR>
> Every time it comes on I get a raw oil smell <BR>
> throughout the house which seems to be more <BR>
> noticeable near the radiators. What could cause <BR>
> this? <BR>
<BR>
> this? <BR>
<BR>
My contractor just replaced my ancient steam boiler (converted from coal) with a new Smith boiler Model 8 series and a Beckett burner. Every time it comes on I get a raw oil smell throughout the house which seems to be more noticeable near the radiators. What could cause this?0 -
Something is
Something is more than likely out of adjustment, call the installer back to fix it. You should not be having this happen but like any new mechanical device there can be some bugs to work out.
Leo0 -
Hello Marica
Its more than likly that dring the process of installing the boiler he had to cut and tread new pipes and maybe some of the precut pipes had oil in them as well. the boiler is new and had tappings cut into it for the piping, these all leave behind oil that floats on the water in the boiler, as it makes steam the oils are carried up with the steam, and comes out the air vents.
The boiler needs to be flushed and blown down and cleaned,
i like to blow it down once after i install a steamer and the n return back and give it a good cleanning.
Call your installer andask them when there going to blow down the boiler
David0 -
Cleaning
It might be very possible that he hasn't skimmed the boiler enough or very thoroughly and there's some thread cutting oil floating on top of the water inside your boiler. You could probably tell if this is the case by observing the gage glass (if so equipped) on the side of the boiler. Generally, you'll see the water level surging up and down as the boiler starts to make steam when contaminants are present. You'd probably also notice a "scum line" in the gage glass itself. Skimming can be a very time consuming process and may involve a couple return trips to get all the gunk out of the boiler. Chemical treatment and cleaning of an old system is always advisable when installing a new boiler. Lot's of crud in the old piping is commonly knocked lose during the change out.0 -
Its a tie Steve LOL
6:04 pm0 -
oil smell-new boiler
> cleaned,
> Call your installer
> boiler
> David
Than0 -
I see that.........
What do they say about great minds...............LOL0
- 87K THE MAIN WALL
- 115 Chimneys & Flues
- 107 Geothermal
- 983 Plumbing
- 389 Solar
