White caulking material?
Brad White_171
Member Posts: 22
most likely.
Here is what is in my specifications as manufacturers to check out:
1) Benjamin-Foster (BF)
2) Chicago Mastic (CM)
3) Insul-Coustic (IC)
4) 3M
5) St. Clair Rubber (SCR)
6) Vimasco (V)
7) Baldwin-Ehret-Hill (BEH)
8) H.K. Porter (HKP)
4) 3M
6) Vimasco (V)
At the ends of every fiberglass covering on the steam mains there is a white caulking material which seals the ends. What is this stuff?0 -
http://forums.invision.net/Thread.cfm?CFApp=2&&Message_ID=304278&_#Message304278
Check this link for picture dscn1947 to see the stuff. It was used very recently as all the steam pipes were replaced in the past 4 or 5 years and insulated.0 -
They look similar
to the Insul-Coustic material (which remains pliable). Comes in caulking gun cartridges and plastic buckets. Sticks to everything....Most of the other cements dry with a flat finish, such as PorterLag.0
- 110 Chimneys & Flues
- 981 Plumbing
- 387 Solar
- 17 Recall Announcements
