Contant Drip from T&P
Richard Edington
Member Posts: 4
I have a reoccurring problem with a T & P valve on a Buderus 79 gallon sidearm with heat supplied by a GB-142 boiler. The T & P has a continual drip that seems to occur during the heating of the water. The house has a booster pump where the ¾ water enters the house; I added a domestic expansion tank and spring check valve on the cold water line entering the sidearm. This did not correct the problem so I added another expansion tank on the hot water side of the sidearm, however, the problem continues. I appreciate any suggestions offered to help remedy this problem.
What is the setpoint of the T & P valve.
What is the shut off pressure of the booster pump?
80 gallon water heater and how much temperature change from cold to hot?
How much expansion volume?
Do you experience water hammer when the toilet, dishwasher, clothes washer, water softener, refrigerator, shower, or any other water using appliance shuts off?
Max pump pressure + thermal expansion + possible undersized expansion volume + water hammer = dripping valve ?
The spring check valve on the cold water inlet to the water heater just removes the cold water piping as part of your expansion volume. If the domestic expansion tank is upstream of the check valve, it is effectively isolated from the hot water system and does nothing to absorb the heating induced expansion.0 -
position of the check
Where did you put the check valve in relationship to the expansion tank? I've a seen a plumber install the check between the indirect and the expansion tank. This will not work. The check should be between the expansion tank and the cold water feed source. The expansion tank should be on the cold water side.0 -
t&p leaking
did you check the pressure on your extrol before you installed it? if not you need to check the tank and match it to your cold water pressure0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 850 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 58 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
