1 Ton Heat Pump
Anybody know of a manufacture that makes a 1 Ton Heat Pump? I am bidding a apartment building that has about 100 apartments with a central chiller & boiler system. When I ran the load calculations I calculated 6300 btu's heat gain and 9100btu's heat loss. The goal is to install separate heat pumps and keep the existing boiler and replace the air handlers with a hot water coil for back-up heat. The electrical service to each apartment is limited.
Thanks,
Ron
Town & Country Mechanical
Richmond, Va
  • Dan Foley
    Dan Foley Member Posts: 1,268
    HP
    Hi Ron,
    We installed a Trane 1-ton heat pump a couple of years ago. I don't know if it made the 13 SEER cut, though. York used to make one as well. Good luck! -DF
  • John Mills_5
    John Mills_5 Member Posts: 952
    Sad to say but...
    looks like 1.5 ton is all still made. I did a search on ARI, nobody makes a split HP under 18,000 BTU. Hate to see them being 3 times the needed size using a 1.5 ton though.
    I suppose no way of putting in a water source heat pump which are made down to 3/4 ton.
  • Brad White_9
    Brad White_9 Member Posts: 2,440
    I would vote
    for water source too but that is a different animal. 1.0 ton DX cooling only is one thing. Heat pumps- have never seen them in a 1.0 ton range let alone 0.75 ton range. I think there is a market though!
  • Christian Egli_2
    Christian Egli_2 Member Posts: 812
    The magic of a shared dumping ground
    Bam, what John Mills said
    Water to air heat pumps units in each apartment that produce either hot or cold air and feed off one water loop that goes to an outdoor coil and the boiler.
    Dump the heat outside in the summer and recuperate outdoor heat in mild weather with the outdoor coil. In deep winter, bump up the heat in the water loop with very low temperature boilers.
    What's ideal during the mixed up season, you can cool some apartments and heat others by trading the heat through the dumping central water loop.
    You could even (if calculations make sense) keep the chiller for dog days summer and precooling of the central loop and not worry about going even smaller on the individual heat pumps.
    There is a company that makes neat units such as these that fit in ceiling tile openings, and the name escapes me right now. Mutlicoil, I want to say.
  • Mitch_4
    Mitch_4 Member Posts: 955
    1 ton HP
    Ductless is all I know of in the 1 ton HP. Check EMI, I think that they are www.enviromaster.com, they used to have the ability to add hot water coil in the air handler (not all), electric strip heat and heat pumps to 9000 btu.
    Mitch
  • Techman
    Techman Member Posts: 2,143
    Small H.P.
    Hi!Daikin makes one that small!The unit put's out ,in heat,70% of its cooling capacity at,I beleave, 0*F or is it +10* ?
  • Rookie_3
    Rookie_3 Member Posts: 244
    McQuay has a 1 1/4 ton, don't know if they put out a smaller one. Comp's are Mitshitsu or Panasonic as we know it.............Dan
  • Ken D.
    Ken D. Member Posts: 836
    HP
    The through the wall PTHP from GE (Zoneline), McQuay, etc. come in the smaller sizes as do the ductless splits such as Sanyo and Mitsuibishi. Carrier also markets these.The smallest standard ducted package and splits go to 1 1/2 Ton that I am aware.
