New Radiator Stinks
John_101
John_101 Member Posts: 12
Apparnetly there is an oil in and on them plus the pipe dope. It is supposed to be cleaned off before it goes in. My burned off eventually.
  • Brian_51
    Brian_51 Member Posts: 6
    My New Radiator Stinks
    I have one pipe steam heating in my house. I recently installed a small, replacement radiator in a room that was missing its original radiator. I painted it with silver, heat resistent paint before installation. Unfortunately, everytime it heats up, it stinks. I was initially under the impression that it was the result of the fresh paint and that the smell would go away after it heated up a bunch of times. However, the smell still exists (although it is slightly less offensive than a few weeks ago). Could it possibly be the pipe compound I used when attaching the new valve to the raadiator and pipe. I had been using just teflon tape for all caps and connections but someone told me I should use pipe compound as well. Was this a mistake? Will the smell eventually go away? My biggest concern is that the new radiator is in my new baby's room and that the smell is potentiually hazardous. Basically, I have been keeping the radiator off when she is asleep - the trade off being that the room stays pretty cold.
    Any suggestions? Thanks in advance.
  • DanHolohan
    DanHolohan Member, Moderator, Administrator Posts: 16,638
    Google
    "Paint VOC" and then look closely at the paint that you used. Could be a problem.
    Retired and loving it.
  • Ken_40
    Ken_40 Member Posts: 1,310
    The idea of using tape and dope...
    Is not new. But it is uneccesary, and a chemical soup created with unknown characteristics. Teflon alone is the sure bet. Dope with oils is potentially problematic. Not so much for the odors relesaed over the lengthy dry-out period, but because the oils leach back into the steam side of the rad, creating a "contaminant" when it slowly passes back into the boiler.
    Use a short hose smaller than a garden variety, as large as a straw and do "selective" sniffing. The scent is one of the following:
    1. Maybe from your aluminum paint (some paints are based on fish oils).
    2. Maybe from the inside of the rad - which would emminate from the vent.
    3. From the paste dope (certainly NOT the teflon tape).
    4. NEVER us dope on the vent threads.
    What do you suspect most?
  • Brad White_9
    Brad White_9 Member Posts: 2,440
    Brian does not smell exactly like a rose you know!
    I try. I do my best. Abused, neglected, painted in colours that would make a harlot blush. And now he says I smell badly... sniff...
    Some days are better than others and now this...
    The Radiator.
  • scott w.
    scott w. Member Posts: 220
    stinky hot paint
    Brian
    Before last years heating season i thought I would spruce up the ole hot water pipes in the basement that connect the cast iron rads. I also painted one small rad on the third floor bath. I used the silver high heat resistance paint. I had paint stink in the basement and third floor bath for quite a while during the heating season. It eventually will go away in a few months.
    SH
