honeywell aquastat L7224U
ray hickethier
Member Posts: 26
I mounted a new L7224U in feb. 07 and since then the customer has put up with an annoyance with the control but finally called today about it. The control stops the oil burner when it reaches the low limit setting momentarliy but then restarts a second later. Can something be done about this?
Honeywell has a one year warranty from date of installation (not date of purchase). You might take advantage of that.0
- 87.2K THE MAIN WALL
- 118 Chimneys & Flues
- 112 Geothermal
- 164 Indoor-Air Quality
- 73 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 15.5K Strictly Steam
