Water by heated heat pump
Arthur
Member Posts: 216
A Chinese heat pump using R22 claims to be able to heat water to 65 deg cent (149 deg F)While it must be a fairly high head pressure is there any way one can get a higher temperature using a different refrigerant at a lower head pressure?
China, with a population of 1.5 Billion,
also claims that ping-pong is their "favorite indoor sport".
So you believe that about their heat pumps??0
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
