steam heat
Antoinette Sandonato
Member Posts: 2
I had my old steam heat boiler replaced last fall with a higher effeciency boiler model number PIN4SNI-HE2. The boiler was also moved a few feet. Since then, when I turn the heat on and the boiler fires and all is still cold, boiler near pipes, pipes, radiators, I hear a noise for about ten minutes coming from all the radiators. I can only describe it as a stealy noise of water flow. This noise is not addressed in Dan's book "We Got Steam Heat" nor can my contractor or boiler manufactur determine its cause. Has any one come across this noise before?
you may
You may want to relocate this post to the heating section of this thread...
However, there's more questions than answers to help you... Can post post some pictures?0 -
That sounds like
a Burnham Independence gas boiler. This model usually makes steam pretty quickly- maybe it's overfilled, or water is being carried into the steam pipes? Regardless, you need a steam pro to look at it.
Try the Find a Professional page of this site. If you're in the Baltimore area, contact me.
- 87.1K THE MAIN WALL
- 58 Biomass
- 117 Chimneys & Flues
- 111 Geothermal
- 163 Indoor-Air Quality
- 72 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 15.5K Strictly Steam
