oil ignitors
David W.
Member Posts: 6
Thanks Bruce, I'm installing a beckett right now. The Carlins date was 02/04, just past the three year warranty, figures, my luck on friday the 13th.........
oil Ignitors
I have a Carlin, model 41000 ignitor that is giving me problems, the 14,000 volt model. Does anyone have a better model to try. thank you..0 -
David
They seem to hold up better when running with an interupted ignition control, some 03 and 05 date codes on them had more problems and some guys are having more luck with the Beckett 14,000V ignitors.0 -
Bigger is better
Have switched to Allanson recently. 17,000 volts. No problems yet.0
- 87K THE MAIN WALL
- 115 Chimneys & Flues
- 107 Geothermal
- 983 Plumbing
- 389 Solar
