boiler for home
kevin coppinger_4
Member Posts: 2,124
finned boiler brand names... Laars, Raypak, teledyne,rbi? They have a sensitive heat exchanger...if there is not enough flow you will get clanging...it can ruin the boiler if not fixed soon....kpc
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=323&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
home boilers
my two year old boiler is making loud clanging noises sometimes. is it air in the lines . maybe someting simple i can do to stop it. please help. after reading some of the e mails on this siter i realize i have to purge the air from the boiloer but where sre the purging valves located. thanks.0 -
a few post down is a picture of a Slant-Fin *~/:)
it is temp heat, the black pipe has "T's" on it, beneath each t is a 1/4 turn ball valve,beneath each of these is a Weezbo connector for a zone or series of sub stations, off that t is a Little red handeled 1/4turn boiler/purge valve/unit heater attachment../bypass
the post is about boilers on a crate...
the 1 1.2" black pipe has a 1/4 turn ball valve to use as a bypass .....
enjoy
*~/:)0
