conversion formula
Brad White
Brad White Member Posts: 2,399
"which weighs more, a pound of gold or a pound of feathers?"
A. Gold.
"If you do not know the answer, say, "I do not know the answer", and you will be correct!"
-Ernie White, my Dad
  • cu/ft = gallons
    any one know how to convert cubic feet into gallons???
  • brucewo1b
    brucewo1b Member Posts: 638
    Here you go
    X.XXX (edit) 7.481 gallons in a cu ft or 1 gallon is 0.1337 cu ft
  • Brad White
    Not for nothing, maybe a typo
    my table says that there are 7.48052 gallons per CF, call it 7.481.
    Your 0.1337 (0.13368 by my chart FWIW) :) is correct, so I suspect a typo inverting the 1 and the 8.
    The volume is at 68 degrees by the way, so if you are storing hotter water you may have to correct things, but if you are that close....
  • brucewo1b
    You sir are correct
    Nothing like transposing numbers to fowl up the works
  • Brad White
    I know you, Bruce
    and you would never let that stand. I tip my hat to you, sir!
    Brad
  • jp_2
    jp_2 Member Posts: 1,935
    ah oh brad????
    volume at 68F??????????????
    a volume is a volume is a volume!!!!
    a gallon is a gallon, which is of course is also a cu ft, cu inch , cu meter..etc.... milliliter :)
    now if you are converting gallons to pounds or kilograms that then would be a temperature story.
  • Brad White
    The volume of water changes
    with temperature, JP. More accurately, it is the density but volume and weight are so interdependent that way.
    If it did not change, then gravity hot water systems were a major hoax :)
    I see your point in the absolute, but volume is relative to temperature when comparing different substances.
    If you filled a cubic foot container made of one material with water at a hotter temperature you would feel short-changed when it cooled. It would be smallest in volume at about 39 degrees F. (4 degrees C.) So one always needs a temperature reference when measuring volumes of anything, gasses, liquids and less affected, solids.
    Anyway, my table stipulated the temperature factor, FWIW
  • jp_2
    word games :)
    of course I agree with density changes vs temp Brad.
    but if you read the question without any assumption, then 4.32 gallons of 200F water will have the same cu ft as 4.32 gallons of 33F water. just don't alter the temperature!
    kind of a trick question if you disect it :)
    weights, densities and volumes can be tricky when mixing water & alcohol!
  • Solarstar
    Solarstar Member Posts: 81
    Converter
  • John Ketterman
    John Ketterman Member Posts: 187
    Reminds me of the question "What is heavier, a pound of lead or a pound of feathers?" Both measured at 70F of course.
  • Brad White_9
    Brad White_9 Member Posts: 2,440
    Hardly...
    but you started it!
    The physics involved transcend words regardless of our wishes...
  • jp_2
    i'm missing it,
    pls explain?
  • Brad White_9
    A pound of gold
    is measured in Troy Ounces and if you are lucky enough, Troy Pounds. We use the Avoirdupois system for most commercial measurements but Troy is used for precious metals.
    A Troy Pound is about 0.83 Avoirdupois Pounds.
    There are 12 Troy Ounces in a Troy Pound, so if you are talking about ounces of gold or feathers, all bets are off. A Troy Ounce is about 10% more that an Avdp. Ounce.
    No whining now! I told you it was a trick question...
  • jackchips_2
    jackchips_2 Member Posts: 1,337
    Love it
    Brad.
    You are so much better at this than I. Will you write my next rebuttal?
    Jack
  • Brad White_9
    Thanks, Jack
    But trust me, you do not want me to write responses to unreasonable change orders.... :)
    I appreciate your support and comraderie!
    Brad
  • ALH_4
    ALH_4 Member Posts: 1,790
    online conversion
    Was is 8.33 or 2.31 or 3.14 or 2.54 or 7.48 or 2.2 or....oops we missed Mars.
    Doesn't help much with gallons per cubic foot though.
    WWW Unit Converter
