G-115 rough start up
Travis_4
Member Posts: 7
I think I saw this in a thread a week or so ago? I also have a customer with a g-115-28 with a carlin burner. On the first start up the unit runs rough for about 10-15 seconds shuts down then starts smooth on the next cycle. I think somebody mentioned changing to a different nozzle. Any thoughts?
carlin
try a 70 degree a or w nozzle--also be sure the control rev b0 -
Dirty Boiler
Clean the boiler as well . Plugs up around the adjustable baffle .0 -
CARLIN
MY MISTAKE-CONTROL SHOULD BE REV C NOT REV B IF YOU ARE USING PRE/POST PURGE0
