need installer - mini-split unit - Pittsburgh area (GrandPAH)
Dave Yates (GrandPAH)_2
Member Posts: 377
be able to post there or would you be willing to tag a contractor and give me their contact info? The customer strikes me as a quality lead that shows promise of more work to come.
Sun Room with radiant heat
needs A/C, but also some extra heat. Owner is interested in the Fujitsu RULX floor console Inverter heat pump. Needs someone to sell and install and provide service.
Evidently her sun room is hydronic 50/50 glycol mix, but on the same circuit as the home. As a result, it's tough to control & they will no doubt be candidates for separating this space to be managed separately.
Installer must be 410A certified & experience with Inverter mini-splits a plus.
Pittsburgh: opportunity knocking!0 -
If you can't find anyone here...
I know a couple of good Pittsburgh guys on HVAC-Talk.0 -
Installer.
Dave,
Email me and I'll give you a couple of contacts.
Jay0
- 119 Chimneys & Flues
- 76 Pipe Deterioration
