Air Vent Sizing???
Steamhead (in transit)
Member Posts: 6,688
and they're not that difficult to add. Measure the length and diameter of your steam mains and we'll tell you what you need.
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=367&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
Air Vent Sizing ???
My house was built in the late 1920s early 1930s and has a single pipe system with no air vents on the main line. Ive been here 4 winters and have not done any maintenance (embarrassingly) during this time, other then drain and add water to the boiler.
I had to replace a badly leaking air vent the other day. Following the chart in Home Depot I bought Maid O Mist sizes 4, 5, and 6 figuring that Ill use them all at some point. When I got home I found that all of the radiators (11 in all) except 1 had size C and D air vents regardless of location to the boiler.
My question is: since there is no main vent should the radiator vents be larger then the recommended size, or should I replace them all with the proper size for their distance from the boiler?
Thanks for reading!
Main size
Steamhead
There are two sections of the main that run in opposite direction from the boiler. Both are L shape, one is 25Ft with 5 radiators off it. The other is 30 Ft with 6 radiators. I'm guessing it's 2" pipe based on a 7.5" circumference. I will try to post some pics later.
Thanks for answering.
Todd0 -
Yes, that's 2-inch pipe
use two Gorton #1 or Hoffman #75 vents on each main. Let us know how much better it works.
Air Vent Sizing
Thanks for the info Steamhead. I'll try to do it next weekend and let you know how it home out.
Todd0
- 167 Indoor-Air Quality
