pump
Bryan_18
Member Posts: 3
I installed a new pump on a WellMcLain gold bioler and it keeps getting air in it what could it be i have bled the air off and it gets air back in about 4 hours
Fresh water has gasses that escape over time as it is heated. Also, unless you purged, you may still have pockets of air in the lines.
TJust a guy running some pipes.0 -
I Agree
You have to either purge the system or bleed each radiator to get that air out.0
- 86.7K THE MAIN WALL
- 56 Biomass
- 105 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 69 Pipe Deterioration
- 951 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
