Hot surface ignitor
![[Deleted User]](https://secure.gravatar.com/avatar/1b8714e1f8ac7db33a1dd00407a960a5/?default=https%3A%2F%2Fvanillicon.com%2F51437e50a93ff7ce99aa31162711f418_200.png&rating=g&size=200)
[Deleted User]
for use on Viessmann products require a special ignitor bracket with shield.
We are also suggesting HO have their appliances converted to spark ignition as they are generally much more reliable...
hot surface ignitor
I am looking for a replacement Ignitor part number is Lochnivar PLT 3400. I know its a Norton ignitor but not sure which. I did not want to buy it from a lochinvar distributor because the price is high.
thanks0 -
Micheal
How high can the price be ??? this things are usually only 25.00 or 35.00 dollars ??
You don't have heat .. is'nt any price worth it ?
Scott
They want $100 with the lochinvar part #. I want to pay $25-$35 so if you know which norton ignitor will cross ref it would be great.0 -
Hummmmm?
Hummmmm? Darn Them things anyway's:)--0 -
W/R 767A-374
Robertshaw 41-406. Norton 271Y. Over 300 mbh, use the PLT 3400. There is a difference.0 -
Norton Ignitor
Both Viessmmann and Weil-Mclin use Noton Ignitors. Try them.0 -
Amen, Fred.
- 86.7K THE MAIN WALL
- 56 Biomass
- 105 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 69 Pipe Deterioration
- 951 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
