\"draw\" off sludge from boiler
Tony Brown
Member Posts: 22
COOL!!
How to \"draw\" sludge from bottom of boiler.
I drained my boiler then refilled it. I then used Squick and fired it up. The Squick instructions say that the "... soft sludge by drawn off. Do not surface blow or drain boiler." How do I "draw" the sludge from the bottom?
squik
Hello. You posted this:
I cannot help you, but did you ever get an answer to your question? I have the same question.0 -
Boiler drain?
Don't you have a boiler drain on the bottom of the unit?
I would make sure the water was still warm but not circulating.0 -
I do have a drain. That's the question. The SQUICK instructions say, "do not drain", but instead "absorded impurities sink to the bottom and may be drawn off". What do that mean, "may be drawn off". After adding SQUICK, what do we do to "draw off"?0 -
"Do not drain" just means don't empty the boiler completely. Your boiler's drain line should have a ball valve or other manual valve on it, to open and close it at will? To 'draw off' (or 'blow down', another term for the procedure), open the valve on the drain line and let a little of the treated water out, just a little, maybe a few liters or so. Then close it again. If your boiler has a lot of sludge, do it again maybe in the evening, then again for a few days but it shouldn't take long to clear out most of the sludge. As Joe Brix said, the boiler should be warm but not circulating, circulating will stir up the sludge and keep it in suspension; not circulating will let it settle to the bottom of the boiler. Doing a couple of little short blow-downs (maybe 2 or 3 seconds?) will move the sludge more effectively than one long blow-down.
I hope this is a little help?
Another question please. My boiler doesn't seem to have skimming or cleanout tees. Is that a major problem?0
- 86.3K THE MAIN WALL
- 53 Biomass
- 90 Chimneys & Flues
- 5.4K Gas Heating
- 100 Geothermal
- 156 Indoor-Air Quality
- 3.4K Oil Heating
- 64 Pipe Deterioration
- 917 Plumbing
- 6.1K Radiant Heating
- 381 Solar
- 14.9K Strictly Steam
- 41 Industry Classes
