spill sw shutdown
j a
Got a call from an old customer today that her boiler was not working w/m gas unit standing pilot. Pilot was lit but burner would not come on ,gave it the usual once over, in general it looked ok but whoever installed it did a sloppy job piping and wiring. jumped thermostat and checked for power at valve 0 volts went to spill sw and found it open so I reset it and boiler lit off......wondered why it went off so I lit a match and was suprised to find it blew it out as well as the water htr did then I opened a window in the basement and it still was blowing it out..Water htr and boiler are common vented into a 6 in smoke pipe 2 ft long then go into a 3 by 9 rect. duct then disappear behind a finished wall and into a chimney...Chimney is an exterior chimney with tera. lining and is apprx 30 ft high droped a lite down and saw no blockage however there is turns and bends at lower end I was unable to inspect ....It was getting dark so I shut down both units and called my chimney man for A.M. appointment to check further...I did go get them a co det. as well as asked who installed unit..so happens he has no lic...house is 60 yrs old with finished basement make up air is not perfect..... looking for thoughts
Ya gota plugged chimney
I'd bet a squrril or a large bird. I have found sea gulls and cats in chimneys. Good luck0
- 87.8K THE MAIN WALL
- 133 Chimneys & Flues
