Wood Burning & Mixing Valve
Eric Johnson
Eric Johnson Member Posts: 174
That's a great thread on wood burning going on down below. I had a few related questions and since that one's getting a little cramped, I thought I'd start a new one.
Some time ago I heard something about installing a mixing valve on a wood-fired boiler that (as I understand it), allows you to use water in the system for heat storage. My house, for example, has about 15 cast iron radiators in addition to the boiler's water storage. Am I correct in thinking that you can somehow (safely) mix return return with supply from the boiler and essentially store heat in the radiators?
What happens when a zone calls for heat? Does a pump simply kick on and supply that zone with hotter water?
Do you need convection for a mixing valve arrangement to work?
Is this a realistic alternative to a heat storage tank?
And finally, my understanding of reverse circulation schemes is that they tend to void boiler warranties. But the mixing valve I heard about sounds like a legitimate deal. Are there any downsides?
