moving 10 year old boiler
dash
dash Member Posts: 12
wanted to know if it was a bad idea to move a 10 year old boiler to new location in same house. or would it be more cost effective to replace unit
  • Jim Eastman_2
    Jim Eastman_2 Member Posts: 27
    Moving 10 year old boiler
    As always, "It depends on .....". If your "old" boiler is an atmospheric boiler vented through Type B or other vertical venting, you will probably have to move the venting to the new location. This could be a problem.
    A new condensing/modulating boiler may be easier to deal with on venting issues with a new PVC vent exiting out through the side wall or rim joist. This solution would provide excellent efficiency and, maybe, the least expensive way to vent the boiler at the new location.
    As mentioned, "It depends!" Not really enough information to give ya much guidance!
    A qualified hydronics contractor could give you the options and attach the $$$ variables to the options.
