Do they make a electric hot water boiler for residential use.
Big O
Member Posts: 1
Does anyone know if they make an electric hot water boiler for residential use? If so eficient are they vs oil
They are considered almost 100% efficient, as there's no heat going up a flue pipe. What you need to look at is cost of electricity vs. Oil.
Argo makes one, Weil-Mclain makes one too.0 -
electric?
i suppose if you have a reactor in your yard or really invest in some good solar panels, but oil is still best 90% of time0 -
Thermolec
Thermolec has several sizes, and has outdoor reset.
If loads are small and supply temperatures are low (like radiant)
then electric boilers are a viable alternative. No flue,maintenance,
usually no mixing valves or expensive controls needed,carbon monoxide not
a concern, no moving parts, so long lasting, some units are less than $700.
You just have to ask yourself if you can deal with the monthly bill.
- 86.3K THE MAIN WALL
- 53 Biomass
- 90 Chimneys & Flues
- 5.4K Gas Heating
- 100 Geothermal
- 156 Indoor-Air Quality
- 3.4K Oil Heating
- 64 Pipe Deterioration
- 917 Plumbing
- 6.1K Radiant Heating
- 381 Solar
- 14.9K Strictly Steam
- 41 Industry Classes
