Unusual Radiators
Brad White_43
Brad White_43 Member Posts: 26
The corner radiator... getting an urge to tell them it needs ....replacement? :)
The pipe radiator- field built obviously to me, but never seen one that big. Looks to be 2" CI fittings?
  • Jeff_74
    Jeff_74 Member Posts: 46
    Big Radiators
    I recently came across these two big radiators at a church. Anyone seen
    others like them? The corner radiator is a 'double one pipe' though I don't think
    they have enough venting.
  • Jeff_74
    Big Radiators
    it has enough venting.
  • Mike T., Swampeast MO
    Mike T., Swampeast MO Member Posts: 6,928
    Have seen pictures of similar rads but not in that exact configuration. Bundy Radiators I think?
  • Brian Stack_2
    Brian Stack_2 Member Posts: 10
    radiator valve removal
    I have a customer with a ten suite apt. one pipe steam system that would like to remove all the radiator valves and replace them with radiator ells so the tenants can play with them. Does anyone see an issue with this? I don't other than not being able to change a radiator vent without turning off the whole system.
  • Brian Stack_2
    sorry wrong spot
  • DanHolohan
    DanHolohan Member, Moderator, Administrator Posts: 16,616
    They have those pipe radiators
    in the Ford Museum. Wonderful!
    Retired and loving it.
  • Steamhead (in transit)
    Steamhead (in transit) Member Posts: 6,688
    That looks like
    either a Bundy or a Reed. Were you able to find the maker's name cast into the base?
  • bob young
    bob young Member Posts: 2,177
    valves
    maybe consider locking devices
  • soot_seeker_2
    soot_seeker_2 Member Posts: 228
    It's a dog
    ... to change out all those valves. You'll probably have to cut some of the unions out of the radiators. Why not just cut the stems off! Hahaha
  • soot_seeker_2
    That's a Bundy...
    ... a quartered version of the round thing I bought last month.
    Long Beach Ed
