valve leaking
John_115
Member Posts: 3
Hello gentlemen. Great site. I have a SlantFin hot water boiler that has a valve that was shooting hot water from the pinhole in one of the caps. The valve is a Watts 240T
175psi about 2" from the pressure relief valve. There are two screw on caps, black and red, the red one is leaking.
I blocked the top to stop the leak until I can get a tech in to replace it. What is this valve and will blocking it for a day or so to keep my heat do any harm?
Thank you
John
Thank you
John
You should have a contractor look at it. While it "sounds" like a Watts DuoVent, I am not sure.
You can also call Slant/FIn technical services on Monday. The phone number is 800 873 4346. Please understand that the technical services person may refer you to your contractor.
Keith Muhlmeister, Slant/Fin Corporation0 -
You are absolutely correct. It is a Duo Vent and it was repaired today. Thank You
John0
- 87.8K THE MAIN WALL
- 129 Chimneys & Flues
- 122 Geothermal
