Not enough heat
HelpWBoiler
HelpWBoiler Member Posts: 2
Hi all! I have a SlantFin Prodogy21 Model KC-90 wall mounted hot water baseboard system. For the last 4 days or so there was pipe noise(banging)I bled system(not sure If corect way)Noise stop still no heat,just warm to the touch. Also, boiler was runing only on Hi fire and for some reason the Aquastat was running at 220. Aquastat was a Honeywell L4080D, which became obsolete, so I replaced it with Honeywell L4008A. After replacing bad Aquastat boiler started to run normal and switching from Hi fire to Low fire with ease. Heat was a bit better, but not hot, just warm and house feels like a freezer.Is there not enough pressure, gas/air ratio not set properly? Please help! I'm not a professional, just a handyman trying my best. My boiler is 8 years old. Thank you.
  • Weezbo
    Weezbo Member Posts: 6,231
    it may have overlived its life time if you dont get the air out.
    of the lines....
  • Keith M
    Keith M Member Posts: 78
    Prodigy 21
    I suggest you contact Slant/Fin's technical services department on Monday. The phone number is 800 873 4346
    Keith Muhlmeister,
    Slant/Fin Corporation
  • HelpWBoiler
    I will get in touch with SlantFin tomorrow. I'll keep you guys updated. Thank you.
