A Radiator not listed in Dan's \"E.D.R\"
Steamhead (in transit)
Member Posts: 6,688
the Bundy or Reed charts in the Library. That should be close enough.
A Radiator Not In Dan's \"E.D.R\"
I actually found a radiator in a home in Bellows Falls, VT,that was not in the E.D.R. book. I need to figure the sq. ft of steam in this unit to size a replacement boiler properly. The radiator is round with 18 separate 1" diameter verticle tubes, arranged with 10 tubes on the outside and 8 on the inside. The unit is 10" in diameter, and 33" in height. Please teach me how to figure out the problem, or where to find the answer. Thanks, Shocked in VT0 -
Can you post a photo?0 -
Bellows Falls
Ron W.--
I just bought a house in bellows falls and need work on the heating system. How do I contact you?0 -
He should have
one of those free Find a Professional ads.Retired and loving it.0 -
Reaching me
I can be reached at Fleming Oil Co. (603)-835-9014.0 -
I will do my best to get a picture. I could not find a manufacturer's label anywhere on the unit.0 -
Sounds like this might be similar
to the one Long Beach Ed just got on eBay. Here's the link to the thread, with pics, is yours similar? If so, you can find ratings in the Library.
http://forums.invision.net/Thread.cfm?CFApp=2&&Message_ID=228346&_#Message228346
Would you like
a free Find a Professional ad?Retired and loving it.0 -
Radiator
I may be having a problem finding your picture. I did find two pics one of a boiler room, the other of piping. Let me know where else to look. Thanx alot, Ron W.0 -
Professoinal listing
Dan, Thank you for the opportunity offered. I need more info about it. Thanx again, Ron W.0 -
Here they are
the first one is the Bundy. I'm not sure what the second one is....
Here are a few pictures
I was able to return to take pics of the radiator in question. Looks alot like a "Bundy", but I am not sure.
If this is indeed a Bundy, how is the square footage figured? Ron W.0 -
Is there a name
cast somewhere in the base? I'd say either a Reed (H.B.Smith Co) or a Bundy (A.A. Griffing)?0 -
Name
I looked everywhere and found no name plates at all. Ron W.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
