Monitor Madness?????
I have a monitor 422 .Very difficult to get parts no wholesalers carry parts or order .I have a hardware store 45 minutes away . Where do you get parts that are reasonable .
  • Roy_4
    Roy_4 Posts: 17
    Monitor Newby
    MPI Experts??,
    Last Spring, I shut down a Hydropulse that had flooded out due to a defective heat exchanger. Never heard back from the customer until this past week (getting cooler out). I stop in and WOW!! A Monitor MZ20-40C mounted on the exterior wall. Never seen one before, Guys. He purchased it out of NJ he claims and wants me to finish installing it.
    I can't seem to figure out 1. how the concentric exhaust/intake elbow attach's to the top of the machine. The throat on the exhaust fitting seems too short to properly connect to the pipe coming up out of the unit??
    2. what's the 3/4" connection on the Return fitting for that connects onto the Return side of the unit????????
    3. do I need MPI components to re-connect the existing indirect hot water tank left over from the Hydropulse????
    I'm really anxious to see/hear this unit operate, as is the customer..........just wish I knew more about it.
    Thanks in advance,
    Roy
    Ontario, Canada
  • Roy_4
    Roy_4 Posts: 17
    MZ
    Thanks, Al...................will call tomorrow a.m.
