Checking CI Rads for leaks
I plug one end and install a pressure gage and valve on the other, then pressurize with 10 or so lbs. of air. Close the valve, disconnect the air and see if it holds.
Good luck,
Jim
  • Phil_8
    Phil_8 Posts: 42
    How do you check used CI Rads for leaks? Would you presserize with nitrogen as if you were checking a new gas line or would you use water at the street pressure? Hate to install then on the second floor and later have them leak?
