to drip or not to drip?
thfurnitureguy_4
John, I have no experiance with the Baseray but do you have to pitch the rad to the 2nd pipe side? I know with radiators that are noisey I add a 1/4 shim to the legs to speed up the run back. Just a thought. Hope it helps.
should I install a drip line?
hello gents,
its getting closer to firing up time for the steam system in my primary residence. I fixed a ton of problems last year with all of your help.
I have one more thing im pondering and Im wondering if there would be enough benifit in doing the project?
my system is 2 pipe steam baseboard downstairs ,1 pipe rads up.
all the runouts go to a wet return except the feed for 3 rads on the second floor (right side of house).
all the rads on this feed heat fine but I suspect the condensate from these 3 rads is whats causing water in a 7' baseboard in a den downstairs as water heads back to boiler through the main it passes the runout for the one noisy (the only gurgling ) baseboard.
I installed a drip just in front of this den baseboard as I did see dropletts in steam and that has taken care of the gurgling for 90% of the time and the baseboard heats fine now .
the only issue is when its wicked cold out and the boiler is running very long cycles this one baseboard will gurgle after about 50 min + run time < im thinking the 3/4" drip (burnham baseray) cant get rid of the water when the boiler is working real hard.
again the baseboard heats fine but only gets noisy when the boiler is cycling a long time. most of the time its quiet . before I added the drip it was gurgleing loud all the time and not heating all the way across.
to put a drip on this one pipe riser? that I mentioned will entail cutting and threading in place, union , T, drop, then run clear across the cellar to pick up the wet return near the floor, a pain in the butt job but If I have to Ill get it done.
your thoughts please,
many thanks and happy heating (though gas bills will be mucho $$$$$ this year (OUCH!!!)
"John"0 -
Can't hurt to drip it
as long as the drip goes below the waterline before connecting to the wet return. Don't try to piggyback this drip onto another one.0
- 87.8K THE MAIN WALL
- 133 Chimneys & Flues
