Outdoor reset (honeywell AQ475)
Robert_15
Member Posts: 62
Burham suggests 140 low and no higher then 220 high end the outside low was set to 10 f. the reason i ask you was your expence in controls. is there a confrotable norm for energy effientcy,
thanks
rob
thanks
rob
Temp setting
Hello Carol, I just intalled a Burnham P205 Input 130,000 with the reset control what is the ideal setting for my boiler with outside temp at the lowest 10 f. I live on Long Island N.Y.
Thank you
Robert0 -
What does the manufacturer suggest?0 -
so is there a setting that would the correct setting for optimum comfort & evergy eff.
thanks
rob0
- 87.5K THE MAIN WALL
- 118 Geothermal
- 394 Solar
- 15.9K Strictly Steam
- 50 Industry Classes
