Not Heating--Question
Tim_31
Anybody know how a device for measuring the percentage of moisture in wood works?
Does it measure the resistance through the wood? And, if it does, why couldn't I use a good ohm meter to measure and then refer to a table to find out how dry my firewood is before I burn it?
Just wondering.
Just wondering.
two types
Tim,
There are two types. One type you jab some pins into the wood, and it measured the resistance. The other type is non-destructive, and it uses the effect that moisture has on the coupling of a radio transmitter and receiver in the unit. The pin type is more accurate, but the n-d type works across a broader range of materials.
jerry
- 87.8K THE MAIN WALL
- 133 Chimneys & Flues
