Barbed Fittings
John Fernandez_2
Member Posts: 40
I am looking for a barbed tee......the application is for my radiant heating systems. I use the Entran (Watts) products and I have been unable to find a barbed tee that will fit the Entran hose.....the tee that I need is
3/4" X 3/4" X 1/2". I have been building my own tees with copper and barbed fittings and find this cost prohibitive. Any help will be greatly appreciated.
You have the correct approch
I doubt that you will find a ready built tee for that product. Certainly not in brass! If you did it would cost as much as the 3 adapters you are currently buying to build your own.
Are you talking about Watts Radiant Onix? I don't believe Entran is around any longer
Curious as to why you need such a fitting.
hot rod
