Pro's Pointers
lchmb
Member Posts: 2,997
I have a feeling that's going to leave a mark!! OUCH..
Pro's Pointers
Tip#1 Don't solder a bunch of 1" fittings and then try and sneak around it to get the one you should have done 1st.) EJW
nice photo
nice photo and a nice reminder i'm just coming out of a nice burn on the inside of my forearm the scab is i believe hurting more then the original burn but she should be off by the end of next week ,the best cure for a burn is fresh aloe from the market with some gause over it it works wonders and cuts down on healing and scarring .I know had got electricuted years back blew up my forearm like a half a gratefruit now just a quater size scar i had also lost the hair on my arm and hada fine red and yellow streak up my arm and across my shoulder to the hand that grounded me thepalm of my hand was yellow and when i broke myself from the circuit i was totally soaking wet .i lived through it and finished the job .Riminder always double and triple check locked out circuits so nobody thinks it a breaker for a lighting circuit peace and good healing clammyR.A. Calmbacher L.L.C. HVAC
NJ Master HVAC Lic.
Mahwah, NJ
Specializing in steam and hydronic heating0
- 86.7K THE MAIN WALL
- 56 Biomass
- 105 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 69 Pipe Deterioration
- 949 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
