Wall mounted water heaters pass code?
Bruce Faul
Member Posts: 2
Can wall mounted water heaters be used as boilers? Will they pass mechanical codes such as the International Mech Code?
In MA, each unit must be approved for the
specific use, but may be multi-use.
NTI's Trinity T and Ti Series were the first boilers approved yesterday by the MA Plumbing Board under the new CO requirements.
You can go here for more info: http://www.nythermal.com/Products/boilers/gas/trinity.htm
Please note that new manual will be posted soon.
- 86.7K THE MAIN WALL
- 56 Biomass
- 105 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 69 Pipe Deterioration
- 949 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
