Opportunities for Fuel Savings on Boilers
Paul Pollets
Paul Pollets Member Posts: 3,666
...than right now to consider adding an outdoor reset control to modulate boiler water temperatures.
Technicians should be offering these controls to every HW boiler client. Owners will enjoy an immediate 10-30% reduction on their gas or oil bill, depending upon the insulation envelope of the home.
Gotta spend some money to save some....There are huge opportunites to upgrade systems for those who know how. We offer a control upgrade to every client we service. Most clients buy the control and thank us for the "tip".
Too bad Tekmar isn't publicly traded...
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=104&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
  • And if You're Considering Boiler Replacement
    No better time than now to choose a condensing AND modulating boiler so that your heat input nearly matches your heat loss.
    Firms should be offering these boilers to every client who is using natural gas or propane. At a minimum, owners will see significant fuel savings. Depending on the age and style of the boiler it is replacing, fuel savings can be extreme. Depending on the type of heat emitters, savings can be extraordinary.
    Depending on the system and the choice of condensing modulating boiler, installation can be so easy as to be described as "plug and play". As long as there aren't other problems to be dealt with, modifications for any condensing/modulating boiler in nearly any system can be kept to a reasonable minimum.
    My own fuel savings were extreme--and reset, constant circulation and TRVs were ALREADY in use. Am attempting to tweak the system to achieve extraordinary.
