GB 142 Adaptor Problem
Darin Cook_3
Member Posts: 389
Yes, we had that issue. Buderus overnited the proper adapters to us. Problem solved. I too tried to file the nuts to no avail. I thought we were the only ones to have that kind of luck. Apparently Buderus had switched vendors for those parts.
Darin
Darin
Adaptors
Anyone Have problems with GB 142 compression adaptors ? My first and the suckers would not slide over the boiler supply tubes ??I mean they did not fit.Nothing in the book......Sat there with a rat tail file for a while grumbling Brooklyn prayers until I gave up .... What gives ??0 -
GB adaptors
Unfortunately there was a shipment of adaptors that where not the right size and not discovered until some of the GB142 had been shipped out. We narrowed down the serial numbers of which units had this issue and sent new adaptors to our representatives. If you encounter this issue please contact the wholesaler or me at 1-800-283-3787 ext.115 and we will get new adaptors to you. Sorry for the inconvience.0 -
GB142
Joe,
Any news on the outdoor re-set and the AM-10 interface for the GB142?
S Davis
Apex Radiant Heating0
- 86.7K THE MAIN WALL
- 56 Biomass
- 105 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 69 Pipe Deterioration
- 951 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
