waste oil venting
hr
hr Member Posts: 6,106
I install Clean Burn nd they require a min. 24 gauge.
I use double walled for through the roof and above. The manual request a Class A UL 103/HT insulated "all fuel" for this portion. DO NOT use Class B or BW for this!
I like the stainless steel jacked type best for exterior use. Watch your clearences also as you penetrate the roof and framing.
hot rod
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=144&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
  • john_92
    john_92 Member Posts: 1
    waste oil venting
    What type of flue material should be used for venting waste oil, Im thinking of allfuel 2100deg. pipe is this over kill
