pressure switch
Nron_13
Member Posts: 164
that will cut out at 30 psi and is rated for potable water system , this is to prvent pumps from running when there is no pressure to the combo radiant system , we have people who turn off the water and drain the HWT leaving our pumps to run dry . most switches are not rated for potable water , does anyone know where to get the flow switch they use in the Rinni water heater that would work
switch
honey well L404B1346 pressuretrol.0
- 86.7K THE MAIN WALL
- 56 Biomass
- 105 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 69 Pipe Deterioration
- 949 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
