What type/brand of PEX?
Patchogue Phil_29
Member Posts: 120
What kind or type of PEX should I use for baseboard heating i.e. interconnecting copper fintube from room to room or making homeruns from fintube to the boiler?
Operating temps to 180* maximum. Should teh PEX be able to stand 200* to be safe?
PEX AL PEX? Other ???
Brand(s) that are good? Brand(s) that I should avoid?
TIA,
Phil
TIA,
Phil
Definitely use PEX-AL-PEX. It expands less, but remember it does expand so with high temperature delta-T's and longer runs, use expansion loops!
Lots of good brands out there.0 -
PAP all the way
I've used Wirsbo MultiCor without any problems, also Kitec. I recently tried the Viega FostaPex, it has an extra PE outer layer and full size pex inner tube. Seems very durable, especially for slabs.
I like the new crimp fitting offered by Wirsbo and Viega. A sturdy, good looking stainless ring. The white tube is the Wirsbo.
hot rod
Wirsbo and Rehau are a couple brands that I like. It should be PEX A (aka Engel Pex). There are three ways to accomplish the cross linking thus A/B/C Pex. The PexA has the highest percentage of cross linking and therefore is stronger and more flexible.0 -
If you use regular PEX to feed high temp baseboards.. make sure you're calculating for and accomodating expansion!! 1.1"/10deg temp rise/100 feet. racks up fast!0
- 86.7K THE MAIN WALL
- 56 Biomass
- 105 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 69 Pipe Deterioration
- 949 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
