Steam Heating System Problem
Steamhead
Member Posts: 17,650
and you don't see water anywhere else, and the boiler hasn't been running, that's almost certainly where the leak is. The reason is that the pipes corrode from the outside as well as the inside.
Consulting
Consulting
I have a steam heating system that slowly leaks water, There is no water around the boiler area. I have had a coiple of plumbers in but they can not agree on the problem. One plumber wants to pressure test the boiler to see if there is a leak another one says the prob;em is in the return piping (I believe I have a one pipe system) and the water is flowing out of the return pipe.
Who do I listen to?
Thanks for any help.
Asher Banks0 -
I have a steam heating system that slowly leaks water. In about seven weeks I have lost five inches of water in the viewing tube. There is no water around the boiler area. I have had a couple of plumbers in but they can not agree on the problem. One plumber wants to pressure test the boiler to see if there is a leak another one says the problem is in the return piping (I believe I have a one pipe system) and the water is flowing out of the return pipe. He wants to test the piping.
Who do I listen to?
Asher Banks0
- 86.7K THE MAIN WALL
- 56 Biomass
- 105 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 69 Pipe Deterioration
- 948 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
