Buderus GB142 LWCO Location
Alan(CaliforniaRadiant)Forbes
Member Posts: 1,243
in the common piping, anywhere above the boiler.
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=53&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
LBuderus GB142 LWCO Location
Were is it recommended to install a lwco on a GB142 ? Is the supply piping to the indirect near the manifold ok ?0 -
LWCO
We install ours off the DHW tap with a tee run up the side, then the isolation valve for the tank coil so there is no valve between the boiler and low water cutoff, make sure you install a auto air bleeder above the LWCO.
S Davis
Apex Radiant Heating0 -
Buderus shows
the LWC in the return piping from the indirect above the boiler with no valves between the LWC and the wall hung heater. Too bad they didn't build a LWC into the unit itself.
LWCO
Do you not think that the LPCO that is installed in the the unit is better than the LWCO,after all,before you get into a low water situation the pressure has to decrease.
Dobber0
- 86.7K THE MAIN WALL
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 68 Pipe Deterioration
- 939 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
