Honeywell controller
Bill Nye_2
Member Posts: 538
Low voltage wiring if often left exposed, the line voltage side would be connected in the 4"sq box.
You can buy 12" X 12" or larger electrical splice boxes or enclosures
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=351&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
controller enclosure
I am going to be installing a Honeywell 8285A Control Center as part of a wood boiler tie in to my existing hot water system. What sort of enclosure do you put these things in? It looks to attach to a 4 inch square junction box but it is too big to actually fit inside it. What sort of cover could I use to protect it.
Any insight would be much appreciated.
jp
jp
- 86.7K THE MAIN WALL
- 56 Biomass
- 105 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 69 Pipe Deterioration
- 949 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
